14 years agoIP Purchase
Good morning. Understand that OpenCore IP must be tethered unless IP is purchased. When I use Quartus programmer, it indicates that I have two evaluation IP cores: Vendor 6af7 Product A2...
14 years agoYes those two cores are indeed the Nios and TSE. If what you are reffering to is the IPS-EMBEDDED suite described here (http://www.altera.com/devices/processor/nios2/ipsuite/ni2-ip-suite.html) then it should cover those two.
