16 years agoIp megafunction license
I have Quartus II, i have installed the evaluation trial 30 days. But in my project there are limitations with eda netlist generation and the pof file for the programmation of the FPGA (DE2 ALTE...
16 years agosorry i have no guide for you, but cfi memory is like accessing any other tri stated memory or device. like sram or a axternal uart, pio ...
don't worry that you try to access a cfi flash, just think it is just an external memory. you need adr line, data in and out bring them together as inout / bidir .. and of course chip select and read/write control you need a fsm that controls your access state (setup, access, hold) so that you enshure you meet the timing. that is realy pretty straight foreward...
