16 years agoIp megafunction license
I have Quartus II, i have installed the evaluation trial 30 days. But in my project there are limitations with eda netlist generation and the pof file for the programmation of the FPGA (DE2 ALTE...
16 years agoso, you say that for the flash memory i can only create an entity in my project and assign directly the pin of my board to this entity?
The problem, in this case, is the clock pin that there isn't in the datasheet or de2 user manual of my board. There are only Address Pins, Data Pins,Chip Enable,Reset and Write Enable. Is it possible? Maybe is the clock fixed and internal?
