16 years agoIp megafunction license
I have Quartus II, i have installed the evaluation trial 30 days. But in my project there are limitations with eda netlist generation and the pof file for the programmation of the FPGA (DE2 ALTE...
16 years agothe flash memory is a straight foreward memory, the ip itself is just a wrapper from external memory to the internal avalon bus.
for the sdram you need an ip that does the refresh as well as the fsm for accessing sdram. have a look at opencores.org there is one pretty simple sdram ip used at the zet project.
