17 years agoIP AltsyncRam -- Read/Write operations issue
Hi all, I have another issue using the RAM IP core generated with the MegaFunction wizard. Here's the entity of my RAM and its instanciation:
GENERIC(
ADDRESS_WIDTH : IN INTEGER ;
PIXE...
17 years agoHi,
I don't see why you get worried about first set of undefined data. Designs normally wash off initial values and look for some start flags e.g. start of a packet ...etc. However if your design depends on that initial read then I can add one more bit to each location to flag '1' indicating that data was written and true. You will need to initialise mem to zero first using a mif file. Though this is overkill. You can also use simpler toggle logic if there is a pattern between write/read.
