14 years agoIP Address
Hi, I am using an ethernet application with NEEK, cyclone III. I am not sure how to find IP address and mac address of the board.Can anyone help with this. thanks.
14 years agoIt's been a while since I worked on that board but if I remember correctly the MAC address is burned into the EEPROM. The board documentation should tell you where it is.
By default the software uses DHCP. So if you enable stdout you can connect to it through the terminal and see what IP is issued by the DHCP server. Alternatively you can hardcode the IP address to make it static, I forget which file you do that it but it's in there somewhere.
