11 years agoIO discrepancy between CIC 10.1 and 13.1
I'm upgrading IP and I see an IO mismatch between the output data widths of the CIC core generated in 10.1 versus the one from 13.1. The documentation for both shows the same formula for calculating...
11 years agocould it be the bitwidth you are referring to depends on cic being decimator or interpolator.
The equation you have given is for interpolator. For decimator you don't subtract log2(R)
