11 years ago
Interrupt Initialization Nios II/e --> Nios II/f
Hi out there!
So i got a Nios2/f License today and ported it into my existing Design.
But when i flash the NiosII Program onto the FPGA the Processor frezzes.
I commented the Interrupt init lines out and now it works.
With the Nios II/e design the Interrupts_Init routines work with the NiosII/f they don´t.
I included the "nios2_gen2_irq.h" and the "alt_irq.h" neither work with the NiosII/f
Here are the Routines:
void init_wiznet_connection_Lost(void) {
/* Recast the edge_capture pointer to match the alt_irq_register() function
* prototype. */
void* edge_capture_ptr = (void*) &edge_capture_wiznet_link;
/* Enable first button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(WIZNET_LINK_BASE, 0x1);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WIZNET_LINK_BASE, 0x0);
/* Register the interrupt handler. */
alt_ic_isr_register(WIZNET_LINK_IRQ_INTERRUPT_CONTROLLER_ID, WIZNET_LINK_IRQ,
handle_wiznet_connection_Lost, edge_capture_ptr, 0x0);
//100 ms TIMER Interrupt initialization
void init_timer_interrupt(void)
int* ptr;
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE, (1<<3) | (1 << 1) |(1 << 0));
IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_0_BASE,0); // Clear TO Bit(Reaching 0)
IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_0_BASE,(alt_u16)(100000000)); // 1 Sek Interrupt // 100 ms Interrupt
IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_0_BASE,(alt_u16)( (100000000) >> 16 )); // 1 Sek Interrupt
alt_ic_isr_register(TIMER_0_IRQ_INTERRUPT_CONTROLLER_ID, TIMER_0_IRQ,handle_timer_interrupts, ptr, 0x0); //Register Interrupt
IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_0_BASE,(1<<2) | (1 << 1) | (1 << 0) ); //Start Timer, IRQ enable, Continuous enable
//Wiznet initialization
void init_wiznet_interrupts() {
* prototype. */
void* edge_capture_ptr = (void*) &edge_capture_wiznet;
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(WIZNET_NINT_BASE, 0x1);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(WIZNET_NINT_BASE, 0x0);
alt_ic_isr_register(WIZNET_NINT_IRQ_INTERRUPT_CONTROLLER_ID, WIZNET_NINT_IRQ,
handle_wiznet_interrupts, edge_capture_ptr, 0x0);
Any ideas on that Topic?
Thank you very much!
    Check if the IRQ hardware connections are still there in Qsys
    The IRQs were still connected so i simply deleted the Nios II from the Qsys design and implemented it again.
    Now it works.
    Thanks again!
