11 years agoInternal memory usage using MegaWizard RAM: 2-port
Hi, I am using 8k, 8-bit wide internal 2-port RAM. Here's the instantiation in Verilog: working_ram ram_test ( .data(ram_data_test), // input [7:0] data; .rdaddress(ram_rd_add...
11 years ago --- Quote Start --- Are you sure you don't write and read same address at same time? --- Quote End --- yes, I checked: read only happens after write is complete. I also changed the IP to have read_enable and tried again; but same issue. thanks,
