14 years ago
Interfacing custom logic to SDRAM controller IP without using NIOS
Does anyone have experience of writing their own Avalon MM master port in Verilog to interface to the Altera SDRAM controller?
I have written the simplest code I could think of to test that I can use the SDRAM controller in my SOPC Builder system: writing 1 x 16-bit word of data to SDRAM using my own Avalon MM Master (in Verilog). The code is:
// Shift register for host_rst_l
always @(posedge host_clk or negedge host_rst_l)
begin
if (~host_rst_l)
host_rst_l_sr <= 2'b0;
else
host_rst_l_sr <= {host_rst_l, host_rst_l_sr[1]};
end
// State Machine which writes to and reads from SDRAM Controller
begin
if (~host_rst_l)
begin
state <= 4'h0;
sdram_read <= 1'b0;
sdram_write <= 1'b0;
sdram_writedata <= 16'h0;
debug_sdram_readdata <= 8'h0;
sdram_byteenable <= 2'b0;
end
else if (host_rst_l_sr == 2'b10)
state <= 4'h1;
// Write Operation
else if (state == 4'h1)
begin
state <= state + 1'b1;
sdram_write <= 1'b1;
sdram_writedata <= 16'h28;
sdram_addr <= 24'h0;
sdram_byteenable <= 2'b11;
end
else if ((state == 4'h2)&(~sdram_waitrequest))
begin
end
// Read Operation
else if (state == 4'h3)
begin
sdram_read <= 1'b1;
sdram_addr = 24'h0;
sdram_byteenable = 2'b11;
end
else if ((state == 4'h4)&(sdram_readdatavalid)&(~sdram_waitrequest))
begin
state <= 4'h0;
debug_sdram_readdata <= sdram_readdata[7:0];
sdram_read <= 1'b0;
end
end
I don't get any response from the SDRAM controller. Can anyone see what I'm doing wrong - my understanding is that the above code complies with the Avalon MM spec.
best regards,
John
    You can use the DMA or SGDMA to control the ext. memory, you just build a simple FSM to read the status of the DMA or write the control data to the DMA's register and monitor the state of the DMA.
    You must first read the AVALON specification and get a little inspection into the AVALON-MM master, it is very simple.
    Badoman is right, take the advantage of SOPC or QSYS, it can save you lots of time in coding the glue logic between your logic and ext. memory controller, especially when you change your design. You can just click and click, then a design is finished.
    --- Quote Start ---
    You can use the DMA or SGDMA to control the ext. memory, you just build a simple FSM to read the status of the DMA or write the control data to the DMA's register and monitor the state of the DMA. You must first read the AVALON specification and get a little inspection into the AVALON-MM master, it is very simple. Badoman is right, take the advantage of SOPC or QSYS, it can save you lots of time in coding the glue logic between your logic and ext. memory controller, especially when you change your design. You can just click and click, then a design is finished.
    --- Quote End ---
    How can I merge my own code into qsys? It seems that no tutorial about this.
