15 years agoInterfacing custom logic to SDRAM controller IP without using NIOS
Hello, Does anyone have experience of writing their own Avalon MM master port in Verilog to interface to the Altera SDRAM controller? I have written the simplest code I could think of to t...
15 years agoThanks Sean,
We don't need to use scatter gather, we have some very simple dma functionality incorporated into our own IP. I'm going to see if I can learn anything from the BFM in the Avalon Verification Suite and if that fails, I will try to use the Avalon MM template. If everything fails, I may come back to you for the SG interface. Thanks again for the response - much appreciated, John
