brian1211
3 years agointel_rtile_cxl_top_cxltyp3_ed with out of order support (ooo enabled) Timing issues (23.2)
In building the intel_rtile_cxl_top_cxltyp3_ed with the ooo enabled we get some design assistant failures around the timing, of concern are these: TMC-20023 - Invalid Set Net Delay Assignment TMC-2...
- 3 years ago
I have checked with the internal team. These DRC messages are expected. The engineering team is still working on cleaning up the sdc constraints in 23.3. The DRC violations should not impact timing, and not cause any functionality problem.
brian1211
3 years agoHi @JonWay_C_Intel ,
Not worried about the DRC checks, it's the 700+ timing constraints from the various *.sdc files that aren't being used that I have issue with. They are below the DRC checks you mention that have been around for a while, the ones below (#7-9):
TMC-20025 - Ignored or Overridden Constraints
TMC-20026 - Empty Collection Due To Unmatched Filter
Are the new ones that are concerning.
