ADua0's avatar
ADua0
7 years ago
Intel Opencl FPGA blocking channel
For Opencl FPGA blocking channel , if there are two independent read/write channel operation, are they actually happening in parallel. In the system viewer of report it appears there are no dependencies so I believe they should happen in parallel but how do you verify?
In code sample below what should happen is that b1 and a should happen in parallel with b2 and a2.
Here is example code,
int b1= read_channel_intel(c1);
int b2 = read_channel_intel(c2);
a = b1 *100 ;
a2 = b2 * 200;
write_channel_intel(c1,a);
write_channel_intel(c2,a2);
  • No, independent channel operations happen sequentially and at an order decided by the compiler. This is why mem_fence(CLK_CHANNEL_MEM_FENCE) is provided to avoid potential deadlocks resulting from channel operation re-ordering by the compiler. In your example it is very much possible that the channel operations might result in a deadlock if they are re-ordered by the compiler. You should make sure to use a mem_fence(CLK_CHANNEL_MEM_FENCE) both between the two channel read operations and the two channel write operations to avoid this.
  • HRZ's avatar
    HRZ
  • ADua0's avatar
    ADua0
    Okay, so would you recommend adding this memory fence for all the channels I have in my design ?
  • HRZ's avatar
    HRZ
    Certainly not; if a certain channel order is required to avoid deadlocks, then you should use a mem_fence to enforce the ordering. If not (i.e. channel operations can be safely re-ordered), then let the compiler decide the order of the operations.
    • ADua0's avatar
      ADua0
      By deadlock you meant which channel operations are stalling maximum amount of time?
