ADua0
7 years agoIntel Opencl FPGA blocking channel
For Opencl FPGA blocking channel , if there are two independent read/write channel operation, are they actually happening in parallel. In the system viewer of report it appears there are no dependenc...
- 7 years ago
No, independent channel operations happen sequentially and at an order decided by the compiler. This is why mem_fence(CLK_CHANNEL_MEM_FENCE) is provided to avoid potential deadlocks resulting from channel operation re-ordering by the compiler. In your example it is very much possible that the channel operations might result in a deadlock if they are re-ordered by the compiler. You should make sure to use a mem_fence(CLK_CHANNEL_MEM_FENCE) both between the two channel read operations and the two channel write operations to avoid this.
ADua0
7 years agoOkay, so would you recommend adding this memory fence for all the channels I have in my design ?
