Intel Agilex 7 FPGA E-Tile Transceiver PHY - Parallel Data
The table that you mentioned, shows the data bit placement when the TX/RX PMA Interface Width = 64 and Enable TX/RX double width transfer = Enabled. The max parallel data width can be 64 bits.
For your requirement, you may need multiple E-tiles, but sadly there is no part with 2 E-tiles in Agilex 7. You will have to change the part that has been selected to accommodate more data width, like F-tile. 3.5.1. Parallel Data Mapping Information
Hi Ash_R,
Thanks for your response. I understand that the table shows the data bits placement, but my concern is that, the table shows the bits upto 128 (interface width = 64 & enabled double width transfer), on the other side the Intel Quartus tool generates only 64 bits using the IP parameter editor. Now I get to know from your point that, E-Tile doesn't support more than 64-bit interface width, but this should be mentioned in the 'E-Tile Transceiver PHY User Guide (UG-20056)' document.
Thanks and Regards,
Arun
