17 years agointegration of DSP Builder model in Quartus
I've designed a simple logic design in DSP Builder, basically reading and writing some I/O ports, after compilation and downloading it works fine running in a Cyclone III. I want to integrate i...
17 years agoThanks a lot for your great help. The vhd block is working now in parallel with the rest of the system.
Now I'm thinking on to send incoming data (input ports) to memory within the memory of the NIOS system by using an MM-Avalon port using a DMA controller. What would be the best way to do it? I would be Using tcl scripts and selecting the block from the library in SOPC Builder?
