10 years agoInstantiation of 2D median filter
Hello everyone
I am trying to instantiate the 2D median filter from couple of days. I am new in this field. I have made a sopc with IP core's - clock, clock video input, scaler and 2d Median filter. I am using the simple camera example from altera that comes with CD. I can see the frame count in the 7-segments that implies camera is running. And so, the filter should be working too. But I don't see any out on LCD display panel. I am confused is it because of 1) fault instantiation of Median filter 2) or because of clock 3) clock video input Here is the part of the code: wire [23:0] LCD_DATA_med; wire [7:0] lcd_r_med; wire [7:0] lcd_g_med; wire [7:0] lcd_b_med; assign lcd_r_med = LCD_DATA_med[23:16]; assign lcd_g_med = LCD_DATA_med[15:8]; assign lcd_b_med = LCD_DATA_med[7:0]; // RGB classification by taking data from SDRAM wire [9:0] wVGA_R = Read_DATA2[9:0]; wire [9:0] wVGA_G = {Read_DATA1[14:10],Read_DATA2[14:10]}; wire [9:0] wVGA_B = Read_DATA1[9:0]; sdram_pll u6 ( .inclk0(CLOCK3_50), .c0(sdram_ctrl_clk), .c1(DRAM_CLK), .c2(CAMERA_XCLKIN), // cmos sensor main clock input,25M .c3(cti0_clk) // cmos sensor lcd pix clock,33M ); median u0 ( //camera-clock video input .alt_vip_cti_0_clocked_video_vid_clk (cti0_clk), // alt_vip_cti_0_clocked_video.vid_clk .alt_vip_cti_0_clocked_video_vid_data ({wVGA_R[9:2],wVGA_G[9:2],wVGA_B[9:2]}), //24 bit data from SDRAM .alt_vip_cti_0_clocked_video_vid_datavalid (rCCD_LVAL), // .vid_datavalid .alt_vip_cti_0_clocked_video_vid_locked (DLY_RST_3), // .vid_locked //clock .clk_clk (CLOCK_50), // clk.clk .reset_reset_n (DLY_RST_3),// reset.reset_n //2D Median: out .alt_vip_med_0_dout_ready (Read), // 'Read' from ltp_controller .alt_vip_med_0_dout_valid (med_dout_valid), // Not sure; just wrote a wire type variable .alt_vip_med_0_dout_data (LCD_DATA_med), // Median output data(8-bit) .data .alt_vip_med_0_dout_startofpacket (dout_startofpacket), //Not sure; just wrote a wire type variable //.startofpacket .alt_vip_med_0_dout_endofpacket (dout_endofpacket) //Not sure; just wrote a wire type variable //.endofpacket ); //ltp controller: touch panel-display output ltp_controller u1 ( .iCLK(ltm_nclk), //LTP_CTRL_CLK .iRST_n(DLY_RST_2), .iREAD_DATA1({lcd_g_med[7:5], lcd_b_med}), .iREAD_DATA2({lcd_g_med[3:0], lcd_r_med}), .oREAD_SDRAM_EN(Read), // lcd side .oLCD_R(lcd_r), .oLCD_G(lcd_g), .oLCD_B(lcd_b), .oHD(lcd_hs), .oVD(lcd_vs), .oDEN() ); If I use "wVGA_R, wVGA_R,wVGA_R" in 'ltp_controller' I can display the image on LCD panel. If use the median filter module than nothing shown on the display but the camra runs and frame count shown on 7-segments. I have also attached the screenshot of SOPC. Can any one please help me out from this problem..Please Thanks and regards Rupok1 Reply
Can anybody please help me? I am still not able to implement 2D median filter..
