12 years agoInphase (I) and Quadrature (Q) components of signals
Hi All, How to calculate the Inphase (I) and Quadrature (Q) components of signals, such as RF signals? I would like to shift the RF signals to a specific baseband frequency and then derive the ...
11 years agoHi Lee,
--- Quote Start --- I can use NCO megaCore function to generate I and Q data now. Got a question for CIC and FIR MegaCore functions. Should the inputs to these two filters in unsigned/sign integer number format or unsigned/sign fractional number format (p4-1, FIR Compiler User Guide attached)? I think unsigned/sign fractional format means a number is always smaller than 1. So floating number input such as 12.111 is not allowed. Is is corret? --- Quote End --- Altera has a habit of changing their IP cores, so any answer I give could be wrong :) The best way to answer these questions is to create a Modelsim simulation and provide the simulation test stimulus and check the response. Then repeat that sequence with the MATLAB model. In fact, the cores usually provide a simple (usually quite useless) testbench. You should be able to determine the appropriate data format using those testbenches. Cheers, Dave
