12 years agoInphase (I) and Quadrature (Q) components of signals
Hi All, How to calculate the Inphase (I) and Quadrature (Q) components of signals, such as RF signals? I would like to shift the RF signals to a specific baseband frequency and then derive the ...
11 years ago --- Quote Start --- But the amplitude of values is between -3.25*10^4 and 3.25*10^4. --- Quote End --- Don't think in decimal, think in power-of-2 3.25e4 = 2^15, so you're simply displaying a 16-bit signed integer number. --- Quote Start --- I'm using the NCO function in DSP Builder (simulink) to display the values. I connected the 16 bit sine and cosine outputs to simulink Scope to display the values. I think the reason of having these big amplitudes is because these values are displayed as signed integer. To fix the issue, --- Quote End --- Why do you think this is an "issue"? Its merely a scale factor. --- Quote Start --- I used Output AlteraBlockset to specify [Number of Bits].[] = 1 for the sign bit and [].[Number of Bits] = 15 for the fraction part of the floating point number. So MSB is the sign bit and the rest of 15 bits is the fraction number. --- Quote End --- What you are trying to do sounds reasonable, however, I don't use Simulink, so I cannot comment on whether this is the correct way to convert to fractional integer. --- Quote Start --- However, the output values are all negative and the cycle lenght is not correct, either. Or should I use another tool to check these values? --- Quote End --- It sounds like there is something wrong with your method of conversion to fractional integer. I'd take a look at the MATLAB documentation and try to find an example that works :) Cheers, Dave
