13 years agoIn qsys,can PCIe IP receive write request that exceeds 512 bytes?
We design our fpga project based on cyclone iv EP4CGX15 without external ram. Since PCIe IP spec says: "A Qsys-generated PCI Express Avalon-MM bridge accepts Avalon-MM burst write requests wit...
13 years agoI haven't read everything carefully, but I think the answer to your question is that "yes", if you are using Qsys, you can program the DMA to transfer a very large amount of data, and the PCIe core will split it up into smaller transfers that will work with the PCIe interface.
