15 years agoimport data into Nios
Could anyone tell me that what is the fastest way to import data to Nios? For instance, I have a verilog module and the output is output [7:0] dout; output source_valid; with a clock rate of 25MHz. Is there any way to import these data into Nios system without loss? Apparently the pio itself can not fulfill this task. Thanks5 Replies
hi guy!!!
you need to put a avalon data bus......this solve your problem avalon mm slave i guess(i cant remenber) cheers Franz Wagner - Altera_Forum
--- Quote Start --- hi guy!!! you need to put a avalon data bus......this solve your problem cheers Franz Wagner --- Quote End --- Hi Franz, Thanks for your quick reply! But can you give a for instance, like a sopc figure? I do not quite understand how to put an avalon data bus... - Altera_Forum
yess.....
at sopc builder ....avalom mm slave ....i guess good luck Franz Wagner - Altera_Forum
Well, I did not quite get that... I can not find this component in sopc builder. whence you have time can you please explain more details for me?
i did that but i cant remenber...... i create a component i guess (or get in internet)
try to use spi slave to avalon mm http://www.alterawiki.com/wiki/spi_slave_to_avalon_mm cheers Franz Wagner
