17 years agoImplement Phase Correlation algorithm
I'm putting a Phase Correlation algorithm in FPGA. Two images in, window them with 2D Hamming. 2D FFT on each. Complex multiply the matrices with one being conjugated first. The magnitude taken of ...
17 years agoYeah, is my error from a previous example.
Normalization divisor is p=H2(0,0) where H2(u,v)=G(u,v)*conj(H(u,vv)). h2(x,y)=ifft(H2(u,v))/p. You must select an adequate word and fractional bits size because h2 values could reach height*widht*max(g(x,y))*max(h(x,y)). assuming your images pixels take values ranging from 0 to 1, you must increase integer part of fixed point numbers to log2(height*widht) and consider my previous explanation for division and square root. I consider you could ommit the square root step, the peak search can be achieved without it.
