15 years agoImplement FFT in parallel
Hello, I have a question about the implementation of FFT in parallel. In the system, I have one main clock, let's call it Fsys. I have several data streams, with a lower rate than Fsys. S...
15 years agoHi,
Thanks for your reply. Do you know is there any HDL example code for FFT without using the altera IP? Meaning some hand coding.
