17 years agoIFFT Info !
Allo, I would like to have a output of 8192 samples @ 16bits real only with IFFT core. I have a input of 4096 samples@16bits in real only (imaginary is 0) !! It's correct ? I set ...
17 years agoMy design is very simple,
I want to make a OFDM transmitter with 4096 carriers in natural order Index(0) = frequency 0 Index(1) = frequency 1 (12.207 kHz) . . Index(4095) = frequency 4095 (50MHz) My sampling rate is 100MHz and no négatif frequency ------------------------------------------------------------------------------------------------------------------------------------------------------- Also, I try to simulate in fonctional mode and the FFT core not work! In burst mode, Sink_ready signal is still high (active) and according to the doc, it should be active only for the length of a block (FIFO) and this length, I do not know !!!!! Do you have a idea about this ? Thank you to help me.
