15 years agoI2C Woes, Opencore and Terasic
I've been trying to get a functional I2C bus in my design for a while now with no luck. I've tried my own and a few open source cores. ALL of them have the same problem. I never receive ACKs. I canno...
15 years ago --- Quote Start --- P.S.: The I2C standard requires I2C devices to filter spikes at both bus lines. I'm missing this feature from the I2C core itself, however. --- Quote End --- That is very strict. Do you know of any core that does this? If the I2C device(s) are on on the same board or in the same case, I wouldn't bother. I would not even bother if it was over a cable of xx meter, as long as the cable is well designed.
