15 years agoI2C Woes, Opencore and Terasic
I've been trying to get a functional I2C bus in my design for a while now with no luck. I've tried my own and a few open source cores. ALL of them have the same problem. I never receive ACKs. I canno...
15 years agoI would expect, that the I2C core has no problems to work with open drain SCL operation, which is according to the standard. It may be however a hardware related issue of a missing or too high resistance pull-up, or strong crosstalk from other signals (possibly SDA) to the SCL node. As long as no I2C device is utilizing clock stretching, push-pull drive of SCL shouldn't be a problem.
P.S.: The I2C standard requires I2C devices to filter spikes at both bus lines. I'm missing this feature from the I2C core itself, however.
