13 years agoI2C interafce on DE1 board
Hi, I'm trying to use the I2C opencore provided by the alterawiki with an Altera DE1 board. I am using Quartus 11 and SOPC builder and I am able to create a SOC system with a NIOS II processo...
13 years ago --- Quote Start --- But I have a question: why Quartus doesn't redirect the signals on the new pins that I select? The clock is always generated on the pin of audio codec of the board also if I select a pin of the board expansion header. --- Quote End --- That must be your error. Check the .pin file and see if Quartus P&R used the pins you thought it should. Cheers, Dave
