13 years agoI2C interafce on DE1 board
Hi, I'm trying to use the I2C opencore provided by the alterawiki with an Altera DE1 board. I am using Quartus 11 and SOPC builder and I am able to create a SOC system with a NIOS II processo...
13 years agoI will try with a pull-up resistors. But I have a question: why Quartus doesn't redirect the signals on the new pins that I select? The clock is always generated on the pin of audio codec of the board also if I select a pin of the board expansion header.
