15 years agoI need a help with simulation RTL DDR2 SDRAM Controllers with ALTMEMPHY for CycloneIV
Hi.
I'm trying to simulate the DDR2 in QUARTUS 10.1sp1 + Active-HDL 8.3sp1 with NativeLink. I simulate the test example. Settings: Controller data rate - full. Enable Half Rate вridge - off. Controller Architecture - High Perforrnance Controller ll. Sarnsung K4T1G164QF. The remaining default settings. Message is displayed in Active-HDL: # File: D:\DinamWork\Cmosis1\simulation\activehdl\cmosis1\src\cmosis_example_top_tb.vhd # Compile Architecture "rtl" of Entity "cmosis_example_top_tb" # Compile success 0 Errors 0 Warnings Analysis time : 14.0 [s] # ELBREAD: Elaboration process. # ELBREAD: Elaboration time 0.4 [s]. asim +access +r -t 1ps -L cmosis1 -L work -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L cycloneive -L cycloneiii testbench/cmosis_example_top_tb.vhd # Error: Cannot find library 'testbench/cmosis_example_top_tb' in the Design Browser # Error: DO_001 in file cmosis1_sim_rtl_vhdl.do line 61. Can not understand where the error is. When I'm trying to simulate the DDR2 in QUARTUS 10.1sp1 + Active-HDL 8.3sp1 without NativeLink. Message is displayed in Active-HDL: # Warning: VCP2515 cmosis_phy_alt_mem_phy.v : (628, 1): Undefined module: cmosis_phy_alt_mem_phy_write_dp was used. Port connection rules will not be checked at such instantiations. Where can I get this cmosis_phy_alt_mem_phy_write_dp?1 Reply
Has anyone been able to run simulations on QUARTUS 10.1sp1 + Active-HDL 8.3sp1 for test example DDR2?
