16 years agoI have some questions!
Hi,I am now useing the triple-speed ethernet Megacore,I have a questions about the control interface,the IP core have 8-bit address,but the mac interface register Map have 12-bit address offset,so ho...
16 years agoDid you properly reset the MAC? Does it receive the clock from the MII side too?
It needs several cycles after reset before it is ready. In that case the waitrequest signal will be asserted.
