AAbro1
6 years agoI have a basic question about Quartus tcl command "get_fanins". so I noticed that there are many options for this command and I'm confused which option should I use?
I'd like understand the difference between these 3 option: get_fanins -async get_fanins -sync get_fanins -clock because in the "get_fanin -help" I didn't understand the difference. is ther...
KennyT_altera
6 years agoWhat u can do is use the tecnology map viewer to look into the netlist.
-asynch Traverse through asynch edges, this normal happened on after LUT1 where no clock involve.
-synch Traverse through synch edges, usually, on the register where clock is involve.
-clock Traverse through clock edges, on the clock path rather than the data path. for example, output of PLL.
