I am trying to create a Viterbi IP block and use in my Arria V GZ design. I am not running an Avalon bus internal. I see that when I choose the Viterbi IP from the DSP/Error Detection and Correction section, it is generated using Qsys.
I have 2 questions:
- Can I directly connect to this IP and not use an Avalon Bus interface
- Can I simulate this core in ModelSiim
- CheepinC_altera
As I understand it, you have some inquiries related to the Viterbi IP in AVGZ devices. Please see my responses to your inquiries as following:
1. Can I directly connect to this IP and not use an Avalon Bus interface
[CP] Yes, you can directly connect this IP in your RTL. Note that the signals at the interface would need to follow the Avalon requirement ie SOP, EOP, Valid and etc.
2. Can I simulate this core in ModelSiim
[CP] Yes, you can generate simulation example design through IP Paramemter Editor -> Generate -> Generate Example Design.
Chee Pin
- GRose12
Chee, Thank you for the information. I followed your instructions and I worked with Steve Zack this morning who is a Arrow/Intel FAE for my territory. He helped me understand that I wanted to use the Viterbi IP in Continuous Mode, so I have changed the IP setup. I have built a ModelSim project to try to simulate the IP and I am still having issues. I don’t see in the ug_viterbi-compiler.pdf document exactly how to run in continuous mode. On page 35 and 36 are the only timing diagrams but they are not for continuous mode. I have setup my ModelSim test bench and here is my waveform output showing that the logic flow with decbit, source_val and decbit being undefined. [cid:[email protected]] My first question is will I be able to simulate the Viterbi IP in ModelSim. If so, what files do I need to include. Best regards, Glenn Rosenthal Ulyssix Technologies, Inc. DATT Summit Phone: 301-846-4800 ext. 301 Fax: 301-846-0686 www.ulyssix.com<http://www.ulyssix.com/> www.dattsummit.com<http://www.dattsummit.com/> "Where technology soars" [cid:[email protected]]<http://www.dattsummit.com/>[cid:[email protected]]<http://www.dattsummit.com/floor-plan>
- CheepinC_altera
Hi Glenn,
Thanks for your update. As I understand it, you are using Viterbi IP in Continous Mode. For your information, I have tested configuring the Viterbi IP in Continous Mode (left other settings as default) and generated the example design from the IP in Q17.0Std. Note that I do not have AV database installed in my local PC and therefore I am generating for CV devices.
After generating the design, I do the following to simulate the example design:
1. Open Modelsim and change working directory to the "simulation_scripts\mentor"
2. Type "source msim_setup.tcl"
3. Type "ld" to start compilation
4. Add the targeted signals to Wave and run the simulation
For your information, the simulation seems to be working fine. I have emailed you the simulation example (viterbi_ii_0_ex_des_cont.zip) that I am running for your reference.
Chee Pin
- GRose12
Chee, Thank you for your answer. I was not able to work on this subject today. I will try your suggestion tomorrow and get back with you. I greatly appreciate your prompt reply. Best regards, Glenn Rosenthal Ulyssix Technologies, Inc. DATT Summit Phone: 301-846-4800 ext. 301 Fax: 301-846-0686 www.ulyssix.com<http://www.ulyssix.com/> www.dattsummit.com<http://www.dattsummit.com/> "Where technology soars" [cid:[email protected]]<http://www.dattsummit.com/>[cid:[email protected]]<http://www.dattsummit.com/floor-plan>
- CheepinC_altera
Thanks. Feel free to keep me posted.
