I am trying to create a Viterbi IP block and use in my Arria V GZ design. I am not running an Avalon bus internal. I see that when I choose the Viterbi IP from the DSP/Error Detection and Correction section, it is generated using Qsys.
Hi Glenn,
Thanks for your update. As I understand it, you are using Viterbi IP in Continous Mode. For your information, I have tested configuring the Viterbi IP in Continous Mode (left other settings as default) and generated the example design from the IP in Q17.0Std. Note that I do not have AV database installed in my local PC and therefore I am generating for CV devices.
After generating the design, I do the following to simulate the example design:
1. Open Modelsim and change working directory to the "simulation_scripts\mentor"
2. Type "source msim_setup.tcl"
3. Type "ld" to start compilation
4. Add the targeted signals to Wave and run the simulation
For your information, the simulation seems to be working fine. I have emailed you the simulation example (viterbi_ii_0_ex_des_cont.zip) that I am running for your reference.
Chee Pin
- GRose126 years ago
Chee, Thank you for your answer. I was not able to work on this subject today. I will try your suggestion tomorrow and get back with you. I greatly appreciate your prompt reply. Best regards, Glenn Rosenthal Ulyssix Technologies, Inc. DATT Summit Phone: 301-846-4800 ext. 301 Fax: 301-846-0686 www.ulyssix.com<http://www.ulyssix.com/> www.dattsummit.com<http://www.dattsummit.com/> "Where technology soars" [cid:[email protected]]<http://www.dattsummit.com/>[cid:[email protected]]<http://www.dattsummit.com/floor-plan>
