15 years agoHPC Memory Controller Write but can't Read
Maybe somebody can help here with this. I have hooked up a HPC memory controller to my SOPC system, configured it the way it is going to be used and everything. No problem with generating, it synth...
15 years agoUsual causes for this are
1 - You have a clock that's not connected. 2 - You have a reset that's not connected or is improperly connected (logic high vs. logic low). 3 - The HPC controller is not coming out of reset because it can't initialize the RAM. Are you using a DDR controller? 4 - Are you running through a clock-crossing bridge? Did you verify that you are meeting all timing requirements? Jake
