16 years agoHowto test a custom avalon slave? TB generator?
Hi, I'm currently trying my luck with writing an avalon slave - however I'm not 100% sure wether my slave works correctly or not. So I was wondering wether there is some kind of testbench(gen...
16 years agoHi,
thanks for your hint! I already had a look at it and it seems that it is exactly the thing I was looking for. However I can't get the tutorial to work :/ When I run the script.do in ModelSim (PE Student Edition 6.5a) I get these messages:# Top level modules: # master_bfm_tb # vsim work.master_bfm_tb # Loading sv_std.std # Loading work.verbosity_pkg # Loading work.avalon_mm_pkg # Loading work.master_bfm_tb # Loading work.test_bench # Loading work.master_bfm_sopc # Loading work.master_bfm_m0_arbitrator # Loading work.master_bfm # Loading work.altera_avalon_mm_master_bfm # Loading work.master_bfm_sopc_burst_0_upstream_arbitrator # Loading work.burstcount_fifo_for_master_bfm_sopc_burst_0_upstream_module# Loading work.rdv_fifo_for_master_bfm_m0_to_master_bfm_sopc_burst_0_upstream_module# Loading work.master_bfm_sopc_burst_0_downstream_arbitrator # Loading work.master_bfm_sopc_burst_0 # Loading work.ram_s1_arbitrator # Loading work.ram # Loading work.altsyncram # Loading work.ALTERA_DEVICE_FAMILIES # Loading work.ALTERA_MF_MEMORY_INITIALIZATION # Loading work.master_bfm_sopc_reset_clk_0_domain_synch_module # ** Warning: (vsim-3017) ram.v(62): - Too few port connections. Expected 23, found 7.# Region: /master_bfm_tb/tb/DUT/the_ram/the_altsyncram # ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'wren_b'. # ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'rden_a'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'rden_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'data_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'address_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'clock1'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'clocken1'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'clocken2'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'clocken3'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'aclr0'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'aclr1'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'byteena_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'addressstall_a'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'addressstall_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'q_b'.# ** Warning: (vsim-3722) ram.v(62): - Missing connection for port 'eccstatus'.# .main_pane.wave.interior.cs.body.pw.wf# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - Hello from altera_avalon_mm_master_bfm# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - $Revision:# 2 $# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - $Date: 2009/08/28 $# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - AV_ADDRESS_W = 16# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - AV_SYMBOL_W = 8# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - AV_NUMSYMBOLS = 4# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - AV_BURSTCOUNT_W = 3# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_READ = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_WRITE = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_ADDRESS = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_BYTE_ENABLE = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_BURSTCOUNT = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_READ_DATA = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_READ_DATA_VALID = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_WRITE_DATA = 1# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_BEGIN_TRANSFER = 0# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_BEGIN_BURST_TRANSFER = 0# 0: INFO: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.hello: - USE_WAIT_REQUEST = 1# 0: INFO: ------------------------------------------------------------# ** Warning: (vsim-3534) - Failed to open file "../ram.hex" for reading.# No such file or directory. (errno = ENOENT) : c:/altera/91/quartus/eda/sim_lib/altera_mf.v(792)# Time: 0 ps Iteration: 0 Instance: /master_bfm_tb/tb/DUT/the_ram/the_altsyncram# ERROR: cannot read ../ram.hex.# ** Warning: (vsim-7) Failed to open readmem file "../ram.ver" in read mode.# No such file or directory. (errno = ENOENT) : c:/altera/91/quartus/eda/sim_lib/altera_mf.v(43706)# Time: 0 ps Iteration: 0 Instance: /master_bfm_tb/tb/DUT/the_ram/the_altsyncram# 0: verbosity_pkg.set_verbosity: Setting Verbosity level=4 (VERBOSITY_INFO)# 250000: FAILURE: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.drive_request: Burst Count must be set > 0# 250000: FAILURE: master_bfm_tb.tb.DUT.the_master_bfm.master_bfm.drive_request: Burst Size must be set > 0# 250000: FAILURE: avalon_mm_pkg.abort_simulation: Abort the simulation due to fatal error incident.# Break in Function abort_simulation at C:/altera/91/ip/altera/sopc_builder_ip/verification/lib/avalon_mm_pkg.sv line 69# Simulation Breakpoint: Break in Function abort_simulation at C:/altera/91/ip/altera/sopc_builder_ip/verification/lib/avalon_mm_pkg.sv line 69# MACRO ./script.do PAUSED at line 8
I could remove the file not found by simply editing the ram.v, but the other error messages remain unsolved. Any ideas? Can someone maybe walk-me-through via skype/icq? Thanks, Pete
