11 years agoHow to use Triple Speed Ethernet MAC IP with medium dependent interface?
I have a design I plan to use Altera Triple Speed Ethernet MAC IP. In the PCB, the FPGA is connected with medium dependent interface (MDI), there is no physical connection between RGMII interface wit...
11 years ago --- Quote Start --- Sorry, I can't help with that - it sounds like you're getting a different copy of the file than I am when I click the link you gave. The one I'm getting is labelled 2014.06.30, and on page 7-23 there is not any MII mentioned at all. Good luck. --- Quote End --- Sorry, I mistook 7-23. It is chapter 7 page 23. I think you mentioned is page 7 to page 23. I will check it and post here if I have more questions. Thanks.
