11 years agoHow to use Triple Speed Ethernet MAC IP with medium dependent interface?
I have a design I plan to use Altera Triple Speed Ethernet MAC IP. In the PCB, the FPGA is connected with medium dependent interface (MDI), there is no physical connection between RGMII interface wit...
11 years ago --- Quote Start --- Did I miss something? --- Quote End --- Sorry, I can't help with that - it sounds like you're getting a different copy of the file than I am when I click the link you gave. The one I'm getting is labelled 2014.06.30, and on page 7-23 there is not any MII mentioned at all. Good luck. Edit: in case there is a terminology problem, page 7-23 (Chapter 7 Page 23) is the 138th page within the PDF. "page 7-23" does not mean pages 7 through 23 (which would consist of the end of the table of contents through page 2-5).
