11 years agoHow to use Triple Speed Ethernet MAC IP with medium dependent interface?
I have a design I plan to use Altera Triple Speed Ethernet MAC IP. In the PCB, the FPGA is connected with medium dependent interface (MDI), there is no physical connection between RGMII interface wit...
11 years ago --- Quote Start --- Which part are you having trouble with? There is no "MDI" checkbox in the GUI, you just need to select the correct variant per the manual. --- Quote End --- So does this mean this IP doesn't support MDI ? Thanks.
