17 years agohow to use multicast with Interniche
I am having problem of enabling multicast functionalitiy in the nichestack.
Interniche website seems to claim it supports multicast I went in th ipport.h and moved IP_MULTICAST define outside of # ifdef UNUSED but the compilation did not pass. What else do i need to do? Has anyone done it? Any example?5 Replies
Hi
I have the same problem. Defining IP_MULTICAST is not the only thing to do. I join a small guide provided by Altera. Compilation is OK but It doesn't work for me. I think we have to modify mcastlist() routine located in allports.c. But I don't know exactly what to do. Mikael. - Altera_Forum
I have worked out how to do multicast, i am posting the steps here for everyone to share. 1. in IPPORT.h You need to turn on 3 defines. # define IP_MULTICAST 1 // obvious one# define ETHMCAST 1 // give the readme.txt in ipmc directory, turn this one# define IGMP_V2 // This is not mentioned anywhere, i figured it out myself by reading the code 2. Do whatever you need to get it compiled. Eg undefine IN_MENUS, comment out codes that causes compilation errors. Appearently they are bunch of code relates to ipmc demostration, and they have no use at all. I would strongly recommend altera to remove them from being compiled in by default, they cause so much confusion. 3. define a dummy mcastlist() nets[0]->n_mcastlist = this_mcastlist; Giving the documentation it said, the idea is to have this done at the mac level. And i am using tse, there is an option called multicast hash table which you can enable. But anyway, i am a pure software guy, i dont have much idea there. But in my case, i did not turn on the option in tse (I tried to turn it on, but then my fpga would not compile, and i am not a hardware guy, i dont know how to fix it). I simply used a dummy mcastlist(), it works anyway. That is all, multicast should work now. BTW, if anyone knows how to detect ethernet cable disconnection, that'd be good. I looked around in TSE and Interniche code, it does not seem possible. - Altera_Forum
Hi
Thanks for your response, I have just a little problem. I defined a dummy mcastlist() :
And I put this line just after Nichestack initializationint dummy_mcastlist(struct in_multi * multi_ptr) { USE_ARG(multi_ptr); return 0; }
Compilation is OK but setsockopt() fails on MULTICAST_IF :extern int dummy_mcastlist(struct in_multi * multi_ptr) ... while (!iniche_net_ready) TK_SLEEP(1); nets->n_mcastlist = dummy_mcastlist;
I am not able to send multicast packet. What's wrong? Have I to do some changes in allports.c? Thanks. Mikael.memset(&local_addr,0,sizeof(local_addr)); local_addr.sin_family = AF_INET; local_addr.sin_port = htons(USED_PORT); local_addr.sin_addr.s_addr = htonl(INADDR_ANY); if((setsockopt (sock, IPPROTO_IP, IP_MULTICAST_IF,(char*) &local_addr,sizeof(local_addr)))<0) { fprintf(stderr,"multicast_if failed\n");} - Altera_Forum
Hi
I am now able to set IP_MULTICAST_IF and IP_ADD_MEMBERSHIP options. It was a socket programming error: considere the following code :
But sendto always returns an error. Any idea? Thanks. Mikael.struct in_addr local_addr; IP4_ADDR(local_address.s_addr,192,168,1,2); if((setsockopt (sock, IPPROTO_IP, IP_MULTICAST_IF,&local_addr,sizeof(local_addr)))<0) { fprintf(stderr,"multicast_if failed\n");} - Altera_Forum
ok it works!
