17 years agohow to use multicast with Interniche
I am having problem of enabling multicast functionalitiy in the nichestack. Interniche website seems to claim it supports multicast I went in th ipport.h and moved IP_MULTICAST defin...
17 years agoHi,
I have worked out how to do multicast, i am posting the steps here for everyone to share. 1. in IPPORT.h You need to turn on 3 defines. # define IP_MULTICAST 1 // obvious one# define ETHMCAST 1 // give the readme.txt in ipmc directory, turn this one# define IGMP_V2 // This is not mentioned anywhere, i figured it out myself by reading the code 2. Do whatever you need to get it compiled. Eg undefine IN_MENUS, comment out codes that causes compilation errors. Appearently they are bunch of code relates to ipmc demostration, and they have no use at all. I would strongly recommend altera to remove them from being compiled in by default, they cause so much confusion. 3. define a dummy mcastlist() nets[0]->n_mcastlist = this_mcastlist; Giving the documentation it said, the idea is to have this done at the mac level. And i am using tse, there is an option called multicast hash table which you can enable. But anyway, i am a pure software guy, i dont have much idea there. But in my case, i did not turn on the option in tse (I tried to turn it on, but then my fpga would not compile, and i am not a hardware guy, i dont know how to fix it). I simply used a dummy mcastlist(), it works anyway. That is all, multicast should work now. BTW, if anyone knows how to detect ethernet cable disconnection, that'd be good. I looked around in TSE and Interniche code, it does not seem possible.
