18 years agoHow to use Median Fillter 2D
Hi,everyone! I am trying to use the IPs in the SOPCBuilder to do some Image processing. In SOPCBuilder,I add the Median Fillter 2D from Video and Image Processing, it showed err...
18 years agoYou have to understand which component is generating the signal which feeds your median filter, and that will be the source component to be connected to your filter. On the other side, there must be another component to be connected at the ouput of your median filter (the sink).
I don't know if you need better understanding of the Nios II development, you may have a look at: http://www.altera.com/literature/tt/tt_nios2_hardware_tutorial.pdf
