8 years agoHow to set up PCIe Gen3 simulation
I've been having issues with this and I'm wondering if I've even set everything up correctly. I have a completed application core that I want to connect to the Arria 10 Avalon streaming hard IP...
8 years agoSounds like you are in correct direction you can use "Generate Test Bench System" or Generate HDL and from "Simulation" tab select Simulation Model language..
Here is the video on how to bring up simulation for Qsys system. https://www.youtube.com/watch?v=e0x5kmvt4f8 Hope this helps. Best Regards, arslanusman2003 (This message was posted on behalf of Intel Corporation)
