13 years agoHow to run gate-level simulation for DDR2 SDRAM Controller
Hi all, I am working with DDR2 SDRAM and I have built a DDR2 SDRAM Controller in Startrix IV (an UniPHY IP) using MegaWizard Plug-In Manager Tool of Quartus 11.1. I have also written a simple t...
13 years agoHi jacklsw86,
Firstly, thank you for your comment. I run synthesis the DDR2 controller and generate its post-fit model (.vo and .sdo file). When run this post-fit model with my testbench, the PLL block in the controller give the right output signal, but the others do not. Command signals to memory (like: mem_cs_n, mem_cas_n, mem_ras_n, mem_we_n,...) is not the same with functional simulation. In functional simulation, DDR2 Controller will automatically generate a sequence of commands that will initialize and calibration the memory. However, with gate simulation, the command remains at No Operation. It means that the initialization fails. Can you talk more about timing constraints in SDC file? I think that we only need .vo and .sdo file to run gate-simulation. How to make the SDC file and put it into the testbench or .do file?
