15 years agoHow to operate with 2 vectors Avalon-MM?
At this moment I'm using a pair of Avalon-MM FIFO write/read to send/receive data to my DSPBuilder block The next step is to add another source of data and then operate byte to byte with the tw...
15 years agoI'm not familiar with DSP builder, but if you want to combine two streams, I think it will be a lot easier by using an Avalon ST input rather than the Avalon MM FIFO. There are some Avalon Stream FIFOs that you can implement in SOPC builder, directly between a source and a sink.
