15 years agoHow to operate with 2 vectors Avalon-MM?
At this moment I'm using a pair of Avalon-MM FIFO write/read to send/receive data to my DSPBuilder block The next step is to add another source of data and then operate byte to byte with the tw...
15 years agoI assume that the DSP block is taking an Avalon Stream as an input? In that case you could read your memory with a SGDMA and convert the data from your external device as a second stream. Maybe add two FIFOs to handle a correct synchronization, and combine the two streams together with a custom component.
