15 years agoHow to operate with 2 vectors Avalon-MM?
At this moment I'm using a pair of Avalon-MM FIFO write/read to send/receive data to my DSPBuilder block The next step is to add another source of data and then operate byte to byte with the tw...
15 years agoHi Daixiwen,
I have two stream of bytes, the first one is coming from external device, the other come from SDRAM. the DSP block must be feeded with both streams by using DMA controller, my main challenge is how can I syncronize the operations byte to byte between different streams. Thanks in advance
