15 years agoHow to operate with 2 vectors Avalon-MM?
At this moment I'm using a pair of Avalon-MM FIFO write/read to send/receive data to my DSPBuilder block The next step is to add another source of data and then operate byte to byte with the tw...
15 years agoI'm not sure I understand your question, but it could be an idea to move data through Avalon streams instead. You can split and merge several streams together if required.
