11 years agoHow to make Master module to access the avalon MM slave peripherals
Hi, I am writing code for making the master module to access the avalon MM slave peripherals (e.g. UFM and ADC). But first I need to know that is there any IP available to access these modules ...
11 years agoYes, USB blaster is needed if using JTAG interface. You did not specify what kind of interface using for the data transfer from the microcontroller. I suggest you can study and apply the concept of SPI Slave to AvalonMaster Bridge in here chapter 18 https://www.altera.com/en_us/pdfs/literature/hb/nios2/qts_qii55004.pdf.
