15 years agoHow to make DDS with NCO megacore function?
I try to make square wave with NCO Megacore Function as below. But, The square wave is not good for use like dds. How to make square wave like ad9850 dds ----- below is VHDL Code -------...
15 years agoYou're requirements aren't clear to me.
Do you need the sine output or only a variable clock? Do you need a low jitter, analog interpolated clock or would a fractional clock be sufficient, as generate by your above example code? In the first case, you need all the analog stuff, e.g. a DAC and a low-pass filter, and using a DDS chip means less effort.
