11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- I see that a test bench was either created by hand --- Quote End --- Pretty much all testbenches are created by hand, since your tests are project specific :) --- Quote Start --- I have a 42s16400j_t.ibs file and an existing test bench --- Quote End --- What is an .ibs file? Sounds like an IBIS file to me, and you would not use that as an SDRAM model. Are you sure you've downloaded something that is actually useful??? --- Quote Start --- handful of steps --- Quote End --- 1. Create Qsys system 2. Instantiate Qsys system in your top-level design (assuming the Qsys is not your top-level design) 3. Instantiate your top-level design in your testbench 4. Instantiate the SDRAM model in your testbench 5. Run your simulation --- Quote Start --- It shouldn't involve writing the simulation for the entire SDRAM initialization process or anything like that --- Quote End --- Why? You need to check that the SDRAM is initialized correctly. Most SDRAM models have a faster initialization sequence in simulation. Cheers, Dave
